Non Ford parts & other stuff for sale If its not for a Ford, or even not car part... this is the room to sell it!! Starting a topic requires you to have purchased a gold membership.
Jenvey 45mm Short Throttle Bodies Zetec SE 1.6/1.7 etc
Old Sep 9, 2017 | 09:50 PM
SLEEMAN's Avatar
SLEEMAN
Newbie
Default Jenvey 45mm Short Throttle Bodies Zetec SE 1.6/1.7 etc
Hey guys
I got these Jenvey 45's for sale as now plans have changed and do not require them any more
They come on a modified inlet to suit the 1.6/1.7 engines, modified slightly so the throttle bodies can fit and work. also the standard fuel rail can be used along with the manifold but I also have purple injectors as you can see on the attached pictures these I believe are around 300cc injectors
the throttle bodies come with the standard kit, but no trumpets, but have got an adaptor plate for the bodies so that an air filter can be used.
comes with
Throttle position sensor
Throttle linkage kit
and push on type fuel rail needs the joining pipe cutting to length and fitting
all together one price at £800
location hemel Hempstead
please contact me for more info etc
Attached Thumbnails Jenvey 45mm Short Throttle Bodies Zetec SE 1.6/1.7 etc-img_6380.jpg   Jenvey 45mm Short Throttle Bodies Zetec SE 1.6/1.7 etc-img_6381.jpg   Jenvey 45mm Short Throttle Bodies Zetec SE 1.6/1.7 etc-img_6382.jpg
