Turbo under boost PO299
Old Sep 9, 2017 | 06:23 PM
lombardrac's Avatar
lombardrac
Default Turbo under boost PO299
Hi, i have a 2010 fiesta 1.6 tdci, that has gone into limp mode. When you plug in scanner it come up with PO299 code. it will clear but under acceleration will come back . any ideas ?
Old Sep 9, 2017 | 08:30 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Check absolutely every hose for splits or leaks, check the wastegate is closing properly and check all small vacuum hoses for splits and that there are none disconnected. Also check the EGR valve isn't stuck open. It's normally something basic and simple that causes a code like that to come up.
Old Sep 9, 2017 | 09:22 PM
ste1806's Avatar
ste1806
Just had this it was the Pressure Converter Valve on our 1.6 tdci focus. it is on the back of the engine just above the driveshaft. More info on this thread https://passionford.com/forum/ford-f...ci-2009-a.html
Old Sep 9, 2017 | 10:12 PM
lombardrac's Avatar
lombardrac
Thanks Guys, will try that
Old Mar 13, 2019 | 10:37 AM
Finneagle64's Avatar
Finneagle64
Default P0299 underboost problem
Did you ever fix this issue? Im having it now and have replaced the pressure converter valve.
