Auxilary shaft pulley
Old Sep 8, 2017 | 10:53 PM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
Default Auxilary shaft pulley
I've got cambelt & crank pulleys off now and want to remove the auxilary shaft pulley. Problem is, it's not coming off! Ford manual says it's only 45 Nm and it's not coming off? Is there something I've missed or could it just be that tight?
Old Sep 9, 2017 | 07:26 AM
155lee's Avatar
155lee
Is that the oil pump/distributor drive pulley you mean?
Mine came off no problem.
The alternator pulley needed a 3 legged puller to come off its shaft and the crank pulley is always stuck and needs heat and persuasion to come off-from experience!
Old Sep 9, 2017 | 09:05 AM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
Yes the distributor pulley.
​​​​​​I guess I need to crank it even harder or have 2nd person for the job to help.
Old Sep 9, 2017 | 09:27 AM
155lee's Avatar
155lee
My bolt slackened off no problem.
Is there not hex shaped flats on the pulley to hold with a spanner like there is on the cam pulleys?
Old Sep 9, 2017 | 11:53 AM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
Yes there is. It's a bit awkward to hold it with big spanner in one hand and try to open the bolt with ratchet on the other hand as it seems to be very tight. I'll have a new try today.
Old Sep 9, 2017 | 12:07 PM
155lee's Avatar
155lee
Can't offer any other advice except the obvious,let the spanner come round till it hits the inner chassis rail then use both hands to pull the ratchet,anti clockwise too.
Good luck
Old Sep 9, 2017 | 10:14 PM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
It came off pretty easily with 2nd person helping lol. Two hands on the spanner while other one was wrenching the bolt open was a lot easier.
