Rear diff ..
Old Aug 4, 2017 | 02:59 PM
2wd's Avatar
2wd
Default Rear diff ..
Hi.
Im trying to find a 7,5" CWP for my 2wd Sapp. Cos. (ratio around 3,9) and has been told that different Sierras and Scorpio/Granadas run them...anyone know witch models and years ???
Old Aug 5, 2017 | 12:11 PM
Marc sierra's Avatar
Marc sierra
The 7.5" version has a ratio of 3.91, there is also a 7" version of which the ratio is 3.92. The 7.5" version you will probably only find on the Scorpio/Granada mk3. The 2.9 versions had a 3.64, so I expect that the 3.91 is on the 2.0 and maybe also 2.4. And if I remember correctly there was even a Scorpio 1.8, which will probably also have the 3.91. Because I don't think there is a shorter ratio used on these cars. The later bug eye Scorpio does have shorter ratios at 4.07 and 4.27 I believe, also both for 7.5" diffs.
Old Aug 5, 2017 | 06:32 PM
2wd's Avatar
2wd
Thanks... Ill try to find one from one of these models asap...
