MK5/6 and Cosworth Fuel Sender Resistance Range
Does anyone know what the resistance range is for the standard Ford fuel gauge sender, as used in the 90s Escorts? Seen the question asked before, but never really seen an answer.
I've got a Stack fuel gauge. It has a number of pre-programmed resistance ranges, or can be custom programmed. I just wondered what the Ford range was and if I might be able to use one of the pre-programmed ones.
