Rosso red Rs turbo build and progress.
Bought myself a red F reg rs turbo in January this year ..car had only done around 110miles in 8 years after a restoration and the owner having a stroke and left unable to drive again...car was looking very 90s ..with clear indicators and smoked Arics in the rear ..I soon got to work changing to ambers and original rears ..also added a rs 3 spoke ..new alternator and a transit connect starter motor ..had a new alarm fitted and started cleaning her up ...I got it booked in for a set up in February at MSD and it turned out it was poorly and only making 88psi on bore 3 ..so its been off the road since and I've been getting all the bits ready for a steel CVH build as im liking the idea of keeping subtle / standardish looking ...spec is
EFI block
EFI Flywheel with ARP bolts and CPS.
PEC Rods
Wossner Pistons
Ford Crank .
ACL bearings
Brand new s2 Ford oil pump
Gated and baffled sump
G.O.N.E bespoke inlet.
Audi A4 DBW throttle body .
Airtec Radiator
Alunox bespoke front mount intercooler.
Alunox bespoke charge carrier .
Deka 60lb 630cc injectors
Mac 3 port electronic boost controller.
Fiesta Turbo electronic drive speed pick up (gearbox)
Kms 4bar map sensor.
Simtek Pro engine management.
Zeitronix zt-2 engine monitor and data logger.
sequential fire .
Motor sport Traction control.
Boost By Gear .
Anti lag .
Launch control
Egt controller .
shift light and engine management light (dash mounted)
full safety strategies in place. Oil , fuel , boost ,water.
AL Developments big port cross Hatch head.
Inlet match ported by A.L Developments.
Harland sharp Roller Rockers.
Newman PH4 cam 200lb springs and solid lifters.
Fiesta Turbo coil pack with fiesta turbo leads.
ND Fabrications over the box exhaust manifold.
ND FABRICATIONS down pipe and bracket.
Mongoose-down pipe back and 3" back box.
TURBO - honeywell Garrett GTX2867R GEN 2.
Garret Turbo speed sensor.
AP racing cp2000-35 clutch kit.
IB5 Gearbox with Quaife diff shot peened Gears.
C.G motorsport billet release thrust bearing.
Rally design quick shift kit linkage .
MSG brake bias Box .
AP racing Front brakes.
cosworth 2wd Rear brakes.
Setrab 16 row oil cooler
A.H Fabrications breather catch can.
mk5 escort clutch peddle and billet quadrant.
MK motorsport Wrc bladed front ARB
Mk motorsport adjustable TCA's
viper rear camber bolts (vw polo)
Full super pro bush kit
V8 land rover engine mounts .
Race line RL7 wheels in 7j x17
Toyo R888 tyres
compomotive Mo5 16x7j
Michelin pilot sport 3.
Stud & nut conversion.
IB5 gearbox case , KA gear set 1-4. puma final drive ,
Shot peened gears , big bearing kit ,Quaife ATB
Kinsey fabrications wheel speed pick up brackets
cherry Hall effect wheel speed sensors.
XYX Fabrications trigger wheel hubs.
Mjv front strut brace.
Heat management by funk Motorsport.
Triple coated ceramic manifold , down pipe , rear housing by Autoflock
here's a few pictures from along the build starting with fetching it to how it is now .
at the petrol station 10 mins after picking it up
The journey begins .
EFI block
PEC Rods
Wossner Pistons
Ford Crank .
ACL bearings
Airtec Radiator
sequential fire .
Boost By Gear .
Anti lag .
Launch control
Egt controller .
Toyo R888 tyres
That's the head work done and built up so far ,
a few snaps from around the car to get some sort of idea of condition.
Amazing eye for the details mate
I hope one day I can do the same to my Sierra 3dr
Good package of godies for the engine
What type of turbo and ecu are you using? Quick spoolup in mind?
Yea mate ..cars that clean it would be criminal to have put the forged Zetec engine in .. liking staying CVH .
Thanks mate ..shes a real solid clean car ...yea head is huge and looking good .
im absolutely choking to get this back on the road ..just got to wait for engineer to get back of holiday and then get the block decked, bored and the crank polished and measured then can order the bearings get it built and fitted then im going to run it in on MFI until ive collected all the bits over xmas to convert to management ..
Is this some Guinness record for the most mods in the shortest time! You've done more since you got it than I've done to mine in 24 years Whatever it's looks great and will go well. Keep up the good work.
Thanks mate ..once I have a plan I like to execute it quite quickly lol ..yea hopefully be the ultimate road spec rs turbo ..thanks mate ill keep updating ..should be finished for first week in September .
Thanks everyone ..only a few weeks to wait and it will be done ..hopefully my new exhaust will be here tomorrow ..brand new mongoose with 3" outward rolled tip .
