Honda CBR1000 throttle bodies on a mk5 fiesta
Hi all.
I've put CBR1000 throttle bodies on my mk5 fiesta with a 1.7L puma lump in... I'm stuck on the electrical side of wiring it together... Do I need to rewire it or buy adaptors etc.? Thanks.
Re wire what ?
Are you trying to run this on the Oem ecu ? Fiesta or Puma ? Or aftermarket ?
If yes it's doable but you will need all the Oem sensors and actuators to match the puma ecu.
So to start with you will need the puma injectors and you will need a plenum on the tb's for the maf.
