2wd cam belt cover bolts
After probably 10 years of not running a belt cover i want to put it back on
Does anyone know what size bolts i need as I've no idea where the originals are now!
Thanks
Thanks
You need the mounting pillars too, two smaller ones for the top and one thinner longer one from down the bottom/front of the cambelt cover, if you have not got them then on the phone to the breakers as I don't think they are available from ford anymore
not sure or the size of the screws/bolt fixings though
