3dr Cosworth fully caged shell
Old Jun 28, 2017 | 06:58 PM
3drRich's Avatar
3drRich
Default 3dr Cosworth fully caged shell
3dr Sierra shell with v5 that originally started life as a mk2 left hand drive French import 2.0is (same as Cosworth shell, bigger gearbox tunnel) NOT COSWORTH ON THE V5.
I bought the car already converted to right hand drive and was a full 3dr Cosworth replica inside and out i then decided I wanted a road/race/track car so converted it to mk1 front and rear then fitted a full multipoint weld in custom cages and seam welded most of the front and rear, then put the car on a rollover jig and completely stripped, stone chipped and 2 pac painted underside in diamond white, removed fuel filler, changed tow eyes to heavy duty, removed roof skin, then prepped and high build primed the whole car which is the stage it's at know.
It was brought over from France around 3 years ago so completely rust free and has a 1989 registration but is currently on a private reg valued at £600 which will go with the car.
Parts it comes with:
Carbon delight full carbon roof skin ready to bond on.
Both Doors.
2 tailgates.
2 whale tail spoilers
3dr Cosworth bonnet (bit scabby and dented but would go again)
Full fibre glass Cosworth arches and skirts.
All door, window and boot rubbers.
All glass and trims except windscreen.
Full 2wd Cosworth car/engine loom.
Steering column with keys and locks.
Also available by separate negotiation is enough parts (all Cosworth) to put the car back on the road including yb turbo engine, gearbox, 6 degree rear beam, ap brakes, plus lots more.
Only reason for sale is i have bought a finished car so no longer have space for this.
Price is £3995
Please get in touch for any further info.
Old Jul 1, 2017 | 11:55 AM
Ridgey's Avatar
Ridgey
Nice shell glws.
Title is misleading though as its not a Cosworth.
Old Dec 1, 2017 | 02:16 PM
marcpompey's Avatar
marcpompey
afternoon
is this still for sale ?
Old Dec 2, 2017 | 05:49 PM
3drRich's Avatar
3drRich
Hi. No it's not I'm afraid.
