Fiesta XR2 This forum is for discussion of all things pertaining to the Ford Fiesta XR2.
Fiesta xr2 fuel gauge problem
Old Jun 16, 2017 | 11:41 AM
155lee's Avatar
155lee
Default Fiesta xr2 fuel gauge problem
Hi all.
Bought a mk2 xr2 and the fuel gauge does not work.
The wiring a bit of a mess and I'm unsure what I'm looking for too.
There is 1 wire going to the sender,although I cannot see it I can see the single wire under the rear seat.
Should this be a positive or negative?
How many wires should go to the sender?
How can I test the actual gauge?
Thanks in advance.
Lee
Old Jun 16, 2017 | 12:15 PM
martysmartie's Avatar
martysmartie
You can short the wire that goes to the sender to earth (at which point the gauge should read full)
If so, the sender is the issue.
Martin
Old Jun 16, 2017 | 12:29 PM
155lee's Avatar
155lee
Just tried that,nothing.
The battery light didn't work either so gave it an earth and that is working now.
How can I test the actual gauge on the dash and should the gauge have a pod feed going to it?
Thanks for the reply ����
Old Jun 16, 2017 | 04:41 PM
martysmartie
Then either the gauge is faulty or there is a break in the circuit.
It does have a switched supply, the ground is the wire to the sender.
Your best off doing the test from the gauge itself.
What you have done with the WL will cause issues, you have effectively just created a light, which will remain on. It should be part of the charging circuit.
Martin
