Where did you install your MAP sensor?
Old Jun 1, 2017 | 04:40 PM
TMitch's Avatar
TMitch
grease monkey
Default Where did you install your MAP sensor?
Hey everyone! Looking for some information on where you've put your MAP sensor.
I'm doing a conversion so I have run into a question of where to put it.
Thanks
TMitch
Old Jun 1, 2017 | 05:19 PM
costina's Avatar
costina
Live long and prosper!!
Anywere upside down and earthed. Best to keep the vac pipe short and use good quality pipe that will not collapse under vac and split on boost.
Paul
