ST suspension
Old May 29, 2017 | 08:53 AM
Mashurst's Avatar
Mashurst
Default ST suspension
Now I know you guys will call me crazy, but I want heavy duty suspension on my ST, but with INCREASED ride height.
Bit like the oldskool rally Mk1 escort set up.
Trouble is, it's been lowered, and all the kits out there seem to be for lowering. Standard height would be better even.
Any suggestions?
Old May 29, 2017 | 09:01 AM
STeve's Avatar
Super Moderator
thats the thing as hardly anyone does stock ride height spring upgrades unless you get a upgraded tdci springs as their ride height is above that of a 170 and all coilovers lower, or maybe fit spring assisters or contact a spring supplier and ask for a extra coil etc
Old May 29, 2017 | 10:46 AM
Mashurst's Avatar
Mashurst
Thanks Steve, that's really helpful.
Of course if get tdci springs then I'll need shocks to match so will the full tdci kit fit the ST mounts etc ?
Old May 29, 2017 | 11:19 AM
STeve's Avatar
Super Moderator
springs simply give you the ride height as the shocks should have enough in them to allow a increase or decrease in height
Old May 29, 2017 | 12:20 PM
Mashurst's Avatar
Mashurst
Thanks Steve, just wanted to make sure I'd have enough movement in the shocks
