Focus 1.8 tdci problems starting after fuel filter change
Old May 17, 2017 | 06:20 PM
routledge92's Avatar
routledge92
Default Focus 1.8 tdci problems starting after fuel filter change
Hi Everyone
I've had a look at other threads and this seems to be a common issue, however I thought I'd done everything reasonable to avoid it.
I've changed the fuel filter on my 52 reg 1.8 tdci focus. I made sure I primed the filter with fuel, I've used a primer to make sure there is no air between tank, filter and engine, and I've loosened injectors until fuel comes through. So now when I crank the engine, it turns over, and is making an effort to start, but will not fire up completely.
I'm supposed to be trading the car in in a week, and they are only giving me £100 for it so don't want to spend money on it, just need to get it going.
Any help would be appreciated
Thanks
Matt
