What fuel pressure reg for Billet fuel rail
Hi All,
I am re-doing my fuel supply and return after a recent problem and I want some recommendations for a good fuel pressure regulator that won't mess up the wonderful mapping by Mark Shead and that will work with a billet fuel rail, I no longer want a rubber pipe and jubilee clips.
What are people using? What threads and dash x fittings etc?
I want to use solid fuel lines under the car with flexi fittings at pump and rail...I assume that is the way to go? Any suppliers recommended?
Thanks Mark, I will buy them and get it ready and then call you if ok to make sure I have the pressure correct...still need to see you to tweak the map once this is done.
Thanks for the links. Will get them ordered.
Got the Jenvey set up ordered. I noticed that in the tech spec it says "if using an alloy fuel rail please support"
So here goes, "go Jenvey, go Jenvey, go Jenvey"...not sure if that is enough support?
I asked MK and he has said to send it to him and he will make sure it is properly supported so will get that done. Now need to source and plan the new solid fuel lines under car and flexi ends...guess Speedflow may do them?
