2003 1.6 zetec ecu
I have a 2003 focus 1.6 zetec and the ecu has a problem it won't spark on cylinders 2/3 I no the key is coded but how can I swap the ecu what else do I have to swap to make the key work ?
Just the ecu and chip in the key.
But I would swap like for like by matching the code. Others may work but keep it simple with like for like.
