Tyre size on front of saff
I have 17"x8" wide wheels in et35 on my sapphire.
They have 215/40 17 tyres and I have rolled arches.
Will I get away running a 225/45 profile on the front?
The car is on konis and not mega low
Cheers Paul
Cheers Paul
Theyll likely rub on the arch liners at the front when you have steering lock on, and probably rub arch.
I've got 225/35 17 on my road wheels (actually.. as in my sig below), same as std wheel tyre combo diameter. Probably give you an extra inch clearance in comparison.
My advice would be do a trial fit on the wheel and tyre combo if you can as you dont want the tyres rubbing on the arches especially on full lock on the front.
