Electric sunroof problem help needed
Old Apr 16, 2017 | 08:35 AM
timsrs's Avatar
timsrs
Default Electric sunroof problem help needed
My electric sunroof on my sapphire does not work
Tested switch and motor is ok put a direct power to it
However if I remove the grey relay in the fusebox and just swap it with the red one next to it it works but does not have the stop between til and slide
I have got another relay ( secondhand ) and still the same
Any advise where to go from here
Old Apr 16, 2017 | 12:52 PM
1374lee's Avatar
1374lee
Try Ford bud, if you get the numbers off the original relay, they maybe able to help. I did this for the fan relay and I managed to get one from Ford, worth a shot for sure.
CheeRS.Lee.
Old Apr 16, 2017 | 02:58 PM
timsrs's Avatar
timsrs
So it looks like both relays are shot
