Ford Puma Discuss the Ford Puma here!
Anyone have a wiring diagram for dipped beam?
Old Apr 13, 2017 | 09:59 AM
youngben's Avatar
youngben
Default Anyone have a wiring diagram for dipped beam?
One of my lights are out. Checked and its not the bulb itself but the wiring on the driver side. The plug is getting no voltage.
Wanted the pin number for the main fuse box so i can bell the cable out to see if its a break in the cable or something else.
Anyone have any info for this?
Old Apr 15, 2017 | 07:13 PM
youngben's Avatar
youngben
Ok so the dipped beam positive pin is earthing when the passenger side light is connected. When the passenger side is disconnected it appears ok. Passenger side light works fine. Put drivers side is blowing fuse! Obviously because it's earthing.
Passenger positive pin is not connected to earth when disconnected but there is continuity between both positive pins on the headlight plugs.
So still on the hunt for a wiring diagram or any advice!?
