2wd rear brake pads different to 4x4 pads
Apr 5, 2017 | 10:11 AM
Shopping around for a new set of rear pads, are the tears different on the 4x4's to the 2wds? And where's the best place to get some decent pads?
Apr 5, 2017 | 01:42 PM
If you're talking about the Cosworths then the rear pads are all the same.
Apr 5, 2017 | 02:43 PM
I put EBC red pads on mine. Seem to do the trick, but everybody will have their own opinions I'm sure
Apr 5, 2017 | 03:14 PM
If you're talking Mk6 RS 2000 rear pads are same 2wd and 4x4.
Cheers, John
Apr 13, 2017 | 10:59 AM
Strangely though...some retailers images of the rear pads show different designs.
I was always under the impression 2wd/4wd were same though
Apr 13, 2017 | 08:38 PM
Resident Wrestling Legend
all the rear pads are going to be the same, seeing as they use the same caliper
