Possible ABS problem with the 3dr
Old Apr 10, 2005 | 04:59 PM
B11GNS's Avatar
B11GNS
Default Possible ABS problem with the 3dr
when i'm driving normally its fine, its just when i come down to almost stopped the pedal sort of vibrates and buzzes and then goes hard, the brakes still seem to work ok although when the pedal goes hard you only touch the pedal and you go through the screen .
Then when you speed up it goes away.
Any help would be appreciated
Old Apr 10, 2005 | 05:26 PM
foreigneRS's Avatar
foreigneRS
Testing the future
had the same problem. replaced front sensors and cured it. i'm not normally one to just change things without diagnosing that they are at fault, but in that case i had some kicking about the garage so it made sense to try them.
Old Apr 10, 2005 | 06:21 PM
B11GNS's Avatar
B11GNS
Its funny you should say that as the problem has been there since i replaced the front wheel bearings and obviously the sensors had to come out, can they go in wrong in any way?
Old Apr 10, 2005 | 08:05 PM
alan rainbow's Avatar
alan rainbow
when fitting the sensors make sure the surface they mount to is clean and i mean shiney metal clean 1/2 a mill can make a big difference
Old Apr 10, 2005 | 08:35 PM
B11GNS's Avatar
B11GNS
cheers alan, will do
Sierrasideways
Oct 8, 2015 06:37 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
155lee
Sep 23, 2015 01:27 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
