Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Steering problems AFTER alignment
Old Mar 24, 2017 | 06:07 PM
richardindorset's Avatar
richardindorset
Default Steering problems AFTER alignment
Just had 2 new tyres and wheel alignment done on my 2009 focus.
The car now drives like a death trap....
When going into a roundabout, the stability control is coming on.
When accelerating on straight road, the car veers off sideways!
Prior to having the alignment done I had replaced a lower control arm on one side.
No issues driving, but the steering was no longer centred, so I took it in for alignment.
Toe in on the side with the new arm was -1.4 (it was more I think, but it maxed out the machine?).
After alignment, all good, until I got it out on the road.
I am going back again tomorrow, but if it's reading ok on the machine, what do I do?
Old Mar 24, 2017 | 06:17 PM
haz87's Avatar
haz87
Check they actually lined it up to the right specs.
I would say potentially you didnt tighten something up right when putting it back together but if it drove fine after other than a squiffy steering wheel then you can write that off.
Were the new tyres put on the front or rear?
Old Mar 24, 2017 | 06:51 PM
RichieST's Avatar
RichieST
Is it the correct front arm you fitted? Not got the wrong.one that's knocked something else out?
Old Mar 24, 2017 | 06:54 PM
Caddyshack's Avatar
Caddyshack
Get them to check everything and whilst on the ramp measure all the parts you can...maybe something is on the car that shouldn't be.
I had 4x4 control arms off an xr4x4, should have been cossie
Old Mar 24, 2017 | 06:57 PM
richardindorset
Well the control arm was a lemforder as specified by euro car parts but I didn't measure it to the mm to be sure! It defo looked identical.
No difference after fitting it and the car drove perfect.
New tyres were on the front.
I have a quick look to see if anything is loose, but all I can see is the marks on the track rod nut where they adjusted it. They only did one side.
Old Mar 24, 2017 | 07:26 PM
RichieST's Avatar
RichieST
What tyres did you have fitted? I had a pair of uni royal rainsports put on my old focus st once, they were lethal!
Old Mar 25, 2017 | 01:12 AM
richardindorset
Dunlop blu response. same as I've always used on there...
Old Mar 25, 2017 | 04:15 PM
richardindorset
Turns out it was my bad!
For some reason, I didn't notice that the replacement suspension arm had an 18mm taper ball joint instead of a 21mm.
Despite it fitting and driving fine for a month. Sods law I hadn't tried to fit a 21mm into an 18mm taper and spotted my mistake first time round.
When the alignment was done, it must have shifted resulting in the ball joint becoming slightly loose.
I just put the right arm on - ECP site shows both arms for the same reg of the car but you have to dig into the details to find that they have different tapers on the ball joints. (which is also annoying)
There was a good online discount, so the new, new arm was only Ł88 for a TRW made arm.
You live and learn.
Protyre Poole were very good, doing the tracking three times (laser 4 while alignment, with new kit), for the price of one. They spotted the play in the ball joint on my second visit.
Old Mar 25, 2017 | 04:52 PM
visa_broke's Avatar
visa_broke
10 Year Member
you was lucky, i've had a balljoint fail on a different brand car and it caused loads of issues when it popped out on the a1 at 80ish
Old Mar 25, 2017 | 05:41 PM
haz87's Avatar
haz87
Wow mega lucky that didnt pop out!
