Rs s1 Hot start problem
Old Mar 22, 2017 | 05:01 PM
Scottt82's Avatar
Scottt82
Default Rs s1 Hot start problem
I have a s1 rs that starts and runs fine if you turn it off when hot if won't start unless bump started
Old Mar 22, 2017 | 05:22 PM
Piston Broke's Avatar
Piston Broke
Heat soak on the starter is a normal issue.
Old Mar 22, 2017 | 05:51 PM
Scottt82's Avatar
Scottt82
Thanks for reply but starter turns engine over fine when hot
Old Mar 25, 2017 | 06:30 PM
Adder's Avatar
Adder
So are you saying the engine turns over fine hot or cold but just struggles to fire when hot ?
Adder
Old Mar 25, 2017 | 06:33 PM
Scottt82's Avatar
Scottt82
Yes turns over same speed hot or cold runs very well but when turned off when hot will not fire off key but bumps straight away
Old Apr 1, 2017 | 07:41 PM
Adder's Avatar
Adder
Try unplugging the blue cold start injector electrical connector below the inlet manifold. Sound weird I know but I'm sure there somthing to it . I can't quite remember but someone on here will tell you more.
