Rs turbo, St150 brake conversion
I am currently in the process of getting the parts together to convert my front brakes to the St150 setup, just wondered what brake lines do people use, the St150 ones or the Rs turbo ones?
cheers,
jack
cheers,
jack
I've fitted st170 brake callipers pretty sure used my normal brake lines don't think it's matters much as long as they are the right thread, I know when I fitted the rear discs had to change brake lines tho not sure what off went down to euro and they sorted me some just need to be longer, if your doing the rears that is
