Cosworth Blow through turbo
Hello ppl I'm new here, really need to know the correct length for std cosworth 2wd conrods, I got a pinto engine 205 block gonna go blow through (I know injection would be better but Ima stick to my carb) wanna cosworth the bottom end for lower CR plus strength, Any help on this matter would be great 👍🏼
cheers.
cheers.
Right sorry bout that I got a std pinto engine 205 block (n/a) I'm gonna turbo it but go with blow through but with the std internals I could only run like 8psi so I wanna cosworth the bottom end, pistons conrods etc to lower the comp and In turn make it a lot stronger so I could run higher boost but I have no idea what the std cosworth conrod length is
I am doing this at the mo
Pinto 205 block
Pinto crank / lightened balanced knife edged
Cozzy rods pistons
Squirt jets ( I will dry sump it in time )
Freshen up ie shells and seals
Head freshened up to
And cam plus springs
Fettle plus exhaust port opening up a bit
Efi inlet with cozzy plenum
( will run efi for now but will end up cozzy management)
Sx200 ex manifold
T3
And a few other bits if I can get them cheap lol
This will be my daily 3dr Sierra so when on cozzy efi I will only run Around
1 bar 1.2 max
As I need it to last
The drive to work need never be boring lol
There is a thread on turbo sport ref" cozzy rods and stuff
Pinto 205 block
Cozzy rods pistons
Sx200 ex manifold
T3
1 bar 1.2 max
