My Ford Fiesta using loads of fuel
Old Mar 4, 2017 | 06:38 PM
Ezzy's Avatar
Ezzy
Default My Ford Fiesta using loads of fuel
Hi guys
Got a major problem with my car
I got a 1993 fiesta Cayman . It was given to me as a project , I've got it back on the road but this thing guzzzles petrol. £20 of fuel does about 40 miles Surely this can't be right ?
So far I've done a service , with plugs and filters and changed thermostat but no change
It's running very rich . In the morning when starting its chucks out a black substance on the floor And judders before moving off ...
Can anyone out there please help ? Apart from this problem it's a great car with only 50k on the clock
Old Mar 5, 2017 | 06:47 AM
studabear's Avatar
studabear
What engine is it?
Could be a faulty coolant temp sensor for the ecu if it's fuel injection.
Old Mar 5, 2017 | 11:38 AM
Ezzy's Avatar
Ezzy
Hi studabear
It's the 1.3 petrol .. I believe it is the fuel injection..?
Where is the temperature coolant temp sensor located please?
I think it could be that as temperature gauge never goes past quarter mark even if we've been out in the car all day
Thanks for your help in advance
Old Mar 5, 2017 | 11:41 AM
155lee's Avatar
155lee
Possibly stuck thermostat,if it thinks it's cold the auto choke will stay on giving the engine more fuel.
Aside from that how much is a litre of fuel where you stay,could just be very expensive ha ha!
Old Mar 5, 2017 | 12:42 PM
Ezzy's Avatar
Ezzy
Hey lee
Well I changed the thermostat about 2 weeks ago but still the same symptoms
Old Mar 12, 2017 | 06:09 AM
iansoutham's Avatar
iansoutham
OCD Victim
Common problem on early CFI units. Put a 1.1k ohm resistor between the two wires for the ECU coolant temp sensor under the inlet manifold. A new sensor will not work. There was a technical bulletin on this when I was at Ford in the early 2000s.
What is happening is the car thinks it is too cold all the time so never gets off choke completely. This removes the full choke sonbrings it back into tolerance.
Old Mar 12, 2017 | 08:45 AM
Ezzy's Avatar
Ezzy
Morning Ian
Thanks for the advice , gonna try this today ,
Would I get this resistor from a Halfords/ screwfix or something?
Old Mar 12, 2017 | 08:47 AM
studabear's Avatar
studabear
Maplin will be your best bet.
Old Mar 12, 2017 | 09:17 AM
Ezzy's Avatar
Ezzy
Hey thanks guys ... I've got the bonnet up but can't seem to find it ... can you be a bit more specific as to where and what it looks like? Thanks
Old Mar 12, 2017 | 09:48 AM
studabear's Avatar
studabear
In the inlet manifold looking at this.
Old Mar 12, 2017 | 09:52 AM
Ezzy's Avatar
Ezzy
Cool will check it out
Old Mar 12, 2017 | 12:09 PM
Ezzy's Avatar
Ezzy
Stupid question but I assume that I need to expose the 2 wires for coolent temp sensor and then hook ohm resistor between them?
Old Mar 12, 2017 | 02:28 PM
studabear's Avatar
studabear
Yeah, that's it.
Old Mar 17, 2017 | 05:04 PM
Ezzy's Avatar
Ezzy
Ok so I got the ohm resistor from maplin .
Now what's the best way on doing this ? Shall I use a soldering iron to attach it or is there an easier method
Old Mar 18, 2017 | 08:27 PM
iansoutham's Avatar
iansoutham
OCD Victim
To start with, I would strip back a bit of wire sheath on each wire (not next to each other, staggered so they cannot touch each other) and wrap the resistor ends round each wire and test it first.
Insulate each connection with a bit of tape.
If it works, remove tape, solder each connection properly and reinsulate.
