ARP head Bolts
Old Mar 1, 2017 | 08:54 AM
shortie's Avatar
shortie
Default ARP head Bolts
Are these any good for a cosworth head i'm going to be running around 540 bhp will these bolts do the job
Old Mar 1, 2017 | 03:04 PM
cossie2's Avatar
cossie2
most of the cossie owners will say no ....long stud is the way to go properly or use oe ones and reduce power..hope it helps..
Old Mar 1, 2017 | 07:47 PM
costina's Avatar
costina
Live long and prosper!!
Do not use them.....
You cannot long stud a 205 block.
There are a few running around that power with std headbolts.
Old Mar 1, 2017 | 07:54 PM
shortie's Avatar
shortie
It's a 200 block
Old Mar 1, 2017 | 08:03 PM
costina's Avatar
costina
I still would not use them. There are many threads on the escort cosworth forum regarding them.
Cossie head has 17thou of expansion and contraction in use hence why cosworth and ford used stretch type bolts. ARP do not stretch and can and will loosen over time.
Hope this helps.
Old Mar 2, 2017 | 08:47 AM
gcfcos's Avatar
gcfcos
My mates just had his 200 block long studded. I think that's the way to go
