How many litres is required to fill a cooling system on a ford focus ?
Feb 27, 2017 | 01:55 PM
I am going to drain the water from my car and put new coolant in, just wondering how many litres of coolant it should take approximately to fill my car's cooling system ?
The car is a mk2 2006 ford focus sport 1.8 TDCI if this helps ?
thanks
Feb 27, 2017 | 02:29 PM
You will never learn
You refuse to listen to any advice given...
From memory if you completely drain it all out you should be able to squeeze in 25 1/2 litres
Feb 27, 2017 | 02:38 PM
Ah hah hah
Feb 27, 2017 | 02:40 PM
thanks
Just add 50/50 mix of water and red/pink antifreeze untill expansion bottle is full and then run it up and when the level drops top it up to the max mark and then once car has cooled down re check the level
Feb 27, 2017 | 03:29 PM
Coolant? Thats a bit old school. Fill it with a 50/50 mix of sand and sawdust - this creates less friction at the waterpump and allows for a few free bhp
Feb 27, 2017 | 03:54 PM
slammedorion
oh bugger off ! I've had enough of your snide remarks
Feb 27, 2017 | 03:55 PM
the same amount that comes out goes back in.
have you considered buying a Haynes manual for your car?
Feb 27, 2017 | 04:41 PM
fuzzy
#logic
Feb 27, 2017 | 05:26 PM
fuzzy
and how exactly do I know how many litres come out when I drain my car ? (btw I currently use tap water and when I undo radiator plug it will just spill onto the ground.
I have a manual for the car
Feb 27, 2017 | 05:27 PM
Rowe
#logic
Feb 27, 2017 | 05:32 PM
I think it should be 'How many litres are required'.
Feb 27, 2017 | 05:38 PM
ProjectBobcat
how many litres then ?
oh, and where is this ford car show ? I'm interested in attending and I may even meet a useful mechanic who can help me !
Feb 27, 2017 | 05:42 PM
FastLife91
by draining it into a bucket. For fuck sake come on, this isn't difficult to logically figure out is it
Feb 27, 2017 | 05:45 PM
I'm also pretty confident that it's illegal to tip antifreeze down the drain.
Garages have to pay to dispose of it
Feb 27, 2017 | 05:53 PM
catch the water in a bucket and mark the level with a permenant marker. if useing a black bucket its best not to use a black marker
Feb 27, 2017 | 06:05 PM
You could try drinking it all and then pissing into a measuring jug
Feb 27, 2017 | 06:07 PM
FastLife91
which ford car show are you on about
Feb 27, 2017 | 06:14 PM
FastLife91
if you only been useing tap water and its been below freezing up north i wouldnt bother
Feb 27, 2017 | 06:29 PM
Rowe
Gatages have to pay to dispose of it
I told you it is only tap water , if it was anti freeze I'd obviously be catching it in a bucket
Feb 27, 2017 | 06:30 PM
Rowe
why would I want to drain tap water in a bucket, I told you it is tap water and It'll just pour onto the ground when I undo the radiator thing.
Feb 27, 2017 | 06:31 PM
If you've had no anti freeze in over winter there's your problem... to late now... it'll be fu!ked
Feb 27, 2017 | 06:34 PM
A thermos flask should be enough...
Feb 27, 2017 | 07:54 PM
FastLife91
if you have a manual why are you asking all these stupid questions? open it...read it.
Feb 27, 2017 | 07:55 PM
FastLife91
so you can measure how much came out since your not smart enough to read the quantities in the manual that you have.
Feb 27, 2017 | 08:11 PM
FastLife91
why don't you just log back into the Focus Owners Club and check the replies as you asked all these questions on there last year.
Feb 27, 2017 | 08:22 PM
Would love to meet this numpty
I'm sure he's doing this for shits and giggles
Feb 27, 2017 | 08:27 PM
He probably drives a corsa. Sounds like a corsa driving chugger.
Feb 27, 2017 | 08:31 PM
Quote:
A 3 cylinder one too
Feb 27, 2017 | 08:48 PM
ray barker
You know.... that great Ford show they have every year in Reykjavik
the one everyone who's anyone on the Ford scene goes to.
Feb 27, 2017 | 09:00 PM
Is that the one rod tarry goes to
Feb 27, 2017 | 09:11 PM
And this is the sort of stuff he puts on YouTube.
Feb 27, 2017 | 10:15 PM
How may litres required to fill that bath? Is it just tap water?
Feb 27, 2017 | 10:24 PM
Just piss in the header tank, its designed to be the same amount as a full piss
Feb 28, 2017 | 05:39 AM
3i Jim
That's disturbing,glad he's not pm'ing me.
I am a bit jealous of his smooth heels,obviously doesn't wear work boots 11 hours a day like me.
Feb 28, 2017 | 06:08 AM
who on earth would fill a bath that full, past the overflow!
Feb 28, 2017 | 08:19 AM
Weird animal
Feb 28, 2017 | 08:23 AM
155lee
He probably uses micro pedi
I bet he looks good in sling backs
Feb 28, 2017 | 08:54 AM
FastLife91
SO YOU KNOW HOW MUCH HAS COME OUT
Feb 28, 2017 | 08:58 AM
markie t
Me
but then again if I fill it up to normal level it looks like I'm sitting in a puddle
To be fair a bigger bath is probably what I need but I'll regularly overfil it just so I get the feeling of having a bath like normal people
Mar 3, 2017 | 01:26 AM
From: An Essex lad now in Christchurch, New Zealand.
Mark V8
Yeah, i'd second this method
If you strain it through a sive you may find a touch of shit particles too.. I also favour a bag of sawdust in with the antifreeze..
This just gets better and better
