Cometic oversize cylinder heat gasket
Old Feb 21, 2017 | 12:44 PM
Faan's Avatar
Faan
Default Cometic oversize cylinder heat gasket
Can someone tell me of the tork of an oversize 2 cylinder heat gasket the same as by a standard cylinder heat gasket?
Old Feb 23, 2017 | 09:57 AM
colins2's Avatar
colins2
what do you mean over size as in thickness?
colins2's Avatar
colins2
what do you mean oversize as in thickness?
Old Feb 23, 2017 | 10:21 AM
Faan's Avatar
Faan
Yes indeed thikness. I saw that Burton has an 070 (1.8mm) for sale. So if I put that one on and I use the standard bolts. Is the tork than the same as by a standard cylinder gasket?
Old Feb 23, 2017 | 07:20 PM
colins2's Avatar
colins2
Default .
Yes use new bolts and torque to std settings.... the burton cometic gaskets 1.78mm are on a 3-4 week delivery as of today when I called
Old Feb 23, 2017 | 09:10 PM
Faan's Avatar
Faan
Ok, thank you very much!
