Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
Headlight issue 2009 ST
Old Feb 21, 2017 | 09:58 AM
Marcopolo's Avatar
Marcopolo
Default Headlight issue 2009 ST
A couple of weeks ago I noticed lighting of the road ahead of me in the dark was really bad. I thought maybe they had moved I but cannot find any info apart from references to an adjustment screw behind the lap units.
Any ideas how this could have happened?
Also, I thought the lights were self adjusting but noticed I cannot see them moving up/down when switched on.
I'd appreciate any help.
Thanks
Old Feb 21, 2017 | 12:07 PM
Rowe's Avatar
Rowe
Skint
has the car had any work done to it recently?
Old Feb 21, 2017 | 12:21 PM
Marcopolo's Avatar
Marcopolo
It was in Service several weeks ago, it was after that when I noticed it.
Old Feb 21, 2017 | 12:35 PM
RichieST's Avatar
RichieST
Does it have xenons? Has it been lowered at all? When I lowered my old ST, there's a levelling sensor on the front os shock, I fitted it back on upside down. Caused the lights to point really low.
Old Feb 21, 2017 | 12:36 PM
Rowe's Avatar
Rowe
Skint
Either one of the levelling sensors will of flipped over the wrong way.
Usually the one located on the drivers side wishbone.
Its a common issue when they've been lifting in the air on a ramp
Old Feb 21, 2017 | 12:45 PM
Marcopolo's Avatar
Marcopolo
I suspect they are Xenons, aren't all ST's? I did notice it the Monday morning after the Ford Dealer had my Car. Another email to them!
Old Feb 21, 2017 | 02:19 PM
Marcopolo's Avatar
Marcopolo
Is this something I can do or does it require a trip to a Dealer?
Old Feb 21, 2017 | 05:11 PM
thebigmacmoomin's Avatar
thebigmacmoomin
No, not all ST's had xenons but that was the pre-facelift. Only ST2 & ST3 had xenons then there wasnt an ST1 on the facelift. If its got the washer jets, then its xenons.
Old Feb 22, 2017 | 06:28 AM
Marcopolo's Avatar
Marcopolo
Gotcha..
I Decided to send a short but frustrated email to the Ford dealership who promptly contacted me. After apologising and being frank that although it's not something they would check after replacing driveshafts....+ they carried out a service afterwards, was not good enough. They're collecting my Car this evening and will remedy it at their expense (unless they find something unrelated which I highly suspect they will not).
