help needed please.
Old Feb 11, 2017 | 01:21 PM
goldenbrown's Avatar
goldenbrown
Default help needed please.
I've just done a battery drain test and it seems I have a drain on fuse 4 which indicates headlamp washers, green fuse 30amp. As soon as I remove the green fuse the engine stalls if I remove the red relay (I) the car runs fine, seems this fuse is more than just headlamp washers. Can anyone spread anymore light on what this fuse and relay does?
golden
