88 orion sticking caliper
Old Feb 8, 2017 | 03:19 PM
L00ney123's Avatar
L00ney123
Default 88 orion sticking caliper
Is this a common thing or is it just plain old bad luck? Is it possible to just take the caliper off press it back in and push it out a few times or do I need to just but even the bullet and get a new one?
Old Feb 8, 2017 | 06:23 PM
haz87's Avatar
haz87
Just old age and/or calipers sitting about unused.
Sometimes pushing in and out a few times (reservoir cap off if on car) could help free it up but if its rusted on the piston internally it'll likely catch/stick soon enough again.
Not difficult to refurb yourself if you want to do a proper job regardless
Old Feb 9, 2017 | 12:11 PM
L00ney123's Avatar
L00ney123
Would mk1 focus front calipers bolt on as I've got a dead focus there I could take the brakes off and just get new disks and pads you see as it's 45 to replace the caliper on the orion
Old Feb 9, 2017 | 12:12 PM
L00ney123's Avatar
L00ney123
I don't get payed till the end of the month and it's my daily run around
Old Feb 9, 2017 | 05:25 PM
haz87's Avatar
haz87
st170 are an upgrade (have to drill the hub to fit), unsure if generic mk1's would fit without modification.
Is Ł45 really that bad when its your brakes we're talking about... on a daily!
If your that stumped for cash, id try forcing out/back in a good few times to get it free'd up, even if only for a few weeks....
Old Feb 9, 2017 | 07:49 PM
Adder's Avatar
Adder
Don't overlook the brake flexis especially if thier original. They can collaspe internally acting like a one way valve !
Adder
Old Feb 9, 2017 | 08:52 PM
L00ney123's Avatar
L00ney123
That's all I want is a quick fix for a few weeks and I will put a pair of new calipers on the front and check the rear brakes while I'm at it
Old Feb 9, 2017 | 08:53 PM
L00ney123's Avatar
L00ney123
Adder
The plan is to upgrade to steel braided ones anyway
Old Feb 9, 2017 | 09:15 PM
RichieST's Avatar
RichieST
Check the sliders are not corroded up too.
