Steering column help needed
ST170 2002 .
Long story but I need to fit a new column. As the barrel/transponder is stuck behind the Kiltech can I change the whole thing and just plug it in and it will work, or will I need to reprogram everything to work with the new transponder and key ? There's one for sale on ebay with everything including the ECU,
http://www.ebay.co.uk/itm/3224122301...%3AMEBIDX%3AIT
but it only comes with one key and I heard you need two to make it work ?
Help.
Help.
