Chirpy sound under the bonnet (Puma)
Old Feb 6, 2017 | 08:18 AM
XR2DylanPop's Avatar
XR2DylanPop
Ford Nut
Default Chirpy sound under the bonnet (Puma)
There's a chirping sound under the bonnet, when idling and accelerating. It's coming from the 'fan' belt/one of the things driven by it. Not sure how to check where it's actually coming from or have any ideas if it could be a just a pulley, the belt or something bigger? 1.7 Zetec Puma
Old Feb 6, 2017 | 08:25 AM
RichieST's Avatar
RichieST
Probably a worn belt. With the engine running, carefully spray a small squirt of water on the inside of the belt. If the noise briefly stops of changes note then that's your problem.
Old Feb 6, 2017 | 03:10 PM
Caddyshack's Avatar
Caddyshack
I thought there would have been lots of joke replies to this such as Budgie, OR "doubt it is a Puma, they growl"
