Fitting compression struts
Old Jan 27, 2017 | 03:59 PM
Cameron's Avatar
Cameron
Default Fitting compression struts
Im planning on fitting an OPi external oil pump to my zetec'd series 2, i've heard the pump sits where the original S2 anti roll bar drops to the TCA, does anyone have any pics of compression struts fitted to the chassis, im not to keen on the idea of cutting into chassis legs without seeing someone elses set up first, or is it possible to weld a bracket to the chassis leg itself?
Old Jan 27, 2017 | 05:39 PM
Caddyshack's Avatar
Caddyshack
I fitted the same on my Cossied pug 205 and that solved the problem. It might be worth looking at the sort of cossie comp struts available and see if they might fit unless you can get some
Old Jan 27, 2017 | 09:32 PM
Cameron's Avatar
Cameron
I've got a pair that have come off a mk4 escort, just need to see how they're attached to the chassis itself
Old Jan 28, 2017 | 07:47 AM
Caddyshack's Avatar
Caddyshack
You would fit some of these to the shell.
http://anembo-engineering.mybigcomme...brackets-pair/
Old Jan 28, 2017 | 07:48 AM
Caddyshack's Avatar
Caddyshack
I can take pics of how they fit on my 205 if you need me to, I will have it on the ramps later
Old Jan 28, 2017 | 03:09 PM
Cameron's Avatar
Cameron
Thanks caddyshack that would be a good help
Old Jan 30, 2017 | 12:09 PM
nigel b's Avatar
nigel b
contact stu collins
he done it to his s2
