Centre bearing for rear prop shaft cos 4x4 needed
Anyone know where to buy a replacement bearing that sits between the box and diff on a Sierra cossie, it is a support bearing after the donut.
I think mine is worn and has some play in it....
And what is it called?
if its the same or similer to the 2wd centre bearings i think there supposed to have a bit as long as theres no vibration with it i could be wrong mine the same im not going to do nothing till it starts vibrating
Thanks, mine does have some vibration and a clock when you pull away sometimes, when I got it it had come off a Sierra that had been broken and the whole prop was rebuilt as it was worn, I can pull it apart by hand so it needs replacing. Would like brand new if can get one.
Replaced mine a year or so back. Pretty sure I used this one from Graham goode. Had it fitted by a driveshaft specialist here in NZ so not sure what's involved in fitting.
http://shop.grahamgoode.com/propshaf...14-59263-p.asp
David
David
David
David
i didnt realise you could get the bearing seperate but thinking about it some one said to me recently you can get the hole thing referbed for about two hundred i dont no if thats right best of checking your u j joints on the shaft there more likely two cause vibration
Ray
I have not heard of him, and a quick search of the white pages (phone book) does not give any hits. I am from Auckland which is also about an hour from Hamilton. I will ask at the next RSOC meeting if anyone has heard of him.
David
David
thanks very much for that if you could post on there forum for a while i tryed joining the rsoc in nz but no joy ive been a bit slack recent viv sent twenty cossies down there there must be some in the rsoc in nz that he exported hes getting me reg numbers i find it very intresting thanks ray
