Cossie dashboard fittment.
Old Jan 22, 2017 | 04:17 PM
timsrs's Avatar
timsrs
Default Cossie dashboard fittment.
Can I have your thoughts on this.
If you look at the pic where the dashboard meets the screen
The dash looks buckled dips low where it's bolted.
It just dont seem right.
What at your dashboards like.
Old Jan 22, 2017 | 06:20 PM
Adam-M's Avatar
Adam-M
They normally do sag between the screw fixings but yours looks asif it's got a big dent just above the ecu cover or does it just appear this way in the pics?
Seems everything sags on a saph.
Old Jan 22, 2017 | 06:58 PM
mattman1234's Avatar
mattman1234
i think it buckles with heat/sunlight over the years
Old Jan 22, 2017 | 07:45 PM
ray barker's Avatar
ray barker
mines straight thank god probably because it hardley sees the light of day i wounder if its possable to haet it up with a heat gun from behind and try to straighten it out put shims underneath or sumut
Old Jan 22, 2017 | 07:52 PM
timsrs's Avatar
timsrs
Hi
yes that's just how the pic has been taken but I see what you mean.
Mine seems to have sagged where it's bolted and not between the bolt holes.
I bet there all the same so will be wasting my time hunting for a new one.
