spark plug gap with group A coil
Old Jan 17, 2017 | 07:49 PM
ray barker's Avatar
ray barker
Default spark plug gap with group A coil
im running agpr 902p motor craft plugs i realise i should have gone for a better plug heinsite an all that but going to run these first saying that i now someone runs them with a saff 380bhp with no issues im on stg 1 2wd saff. i no with a std coil the gaps have to be closed up but now ive fitted the grp a coil what is the best gap ive allready noticed after starting it tonight it idles allot smoother thanks ray
Old Jan 17, 2017 | 09:51 PM
martysmartie's Avatar
martysmartie
I doubt it's much larger, it's more due to the ignition system where the misfiring lies, although the plugs can count to an extent.
The coil you have will provide a stronger spark, so you may be able to open them slightly more.
Martin
Old Jan 18, 2017 | 11:45 AM
cossie2's Avatar
cossie2
when i had that set up gap was 0.6..
Old Jan 18, 2017 | 03:46 PM
grcossie's Avatar
grcossie
I have used these for many years, and have 1mm gap with grpa coil and 1.5 bar boost
https://www.msdperformance.com/produ...ver/parts/6201
Old Jan 18, 2017 | 04:24 PM
gcfcos's Avatar
gcfcos
Same here
Old Jan 19, 2017 | 10:05 PM
ray barker's Avatar
ray barker
ill go with 0.6 then thanks chaps
