Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Jacking point
Old Jan 17, 2017 | 01:21 PM
oldboy's Avatar
oldboy
Default Jacking point
I have attempted to 'search out' but failed miserably, so can anyone show me exactly where I can safely lift and support the 'rear' of my '02 hatchback as nowhere looks substantial enough?
Many thanks
Old Jan 17, 2017 | 06:34 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
The sill area isn't the best and can flex with the jack under it. So what I do usually is place it under the hub axle. If jacking both sides I chock the front wheels. Make sure to use a trolley jack as the one provided is cat.
Old Jan 18, 2017 | 09:02 AM
Rowe's Avatar
Rowe
Skint
i've always jacked my Focuses (plural?) on the sills with no issues. Although i would advise caution if you're jacking towards the rear of the car, as the sills can rot and you will make a mess.
As per the answer above, underneath the hub is a good alternative, or even on the subframe if you can jack the jack underneath with enough travel.
