Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
59 plate ST engine failure limp mode
Old Jan 13, 2017 | 07:39 PM
Samantha Mcbride's Avatar
Samantha Mcbride
Default 59 plate ST engine failure limp mode
Hi I have a Focus ST 2.5 59 plate, before Christmas it started showing engine failure and going into limp mode, it has been in the garage and had a full service and the fault diagnostics came up that the accelerator sensor was faulty, it has had a new switch today all seemed well but I've taken it out tonight and it the engine failure warning came up again although when I switched it off and on again it cleared, any advice would be welcome
Old Jan 16, 2017 | 09:29 AM
Mick.M's Avatar
Mick.M
I've got a 07 st, when i had simular problems with mine, I needed a new battery.
