Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
p0234 reconned and 3k code
Old Jan 8, 2017 | 11:37 PM
Alan Barclay's Avatar
Alan Barclay
Default p0234 reconned and 3k code
why I changed oil has blanked egr remapped dpf deleted and use good feul n oil change 2xrecommeded so at loss only change N cleaned KnN n drilled air box 150g/sec from 100 seems go much past 100 get code#Po234-60 only botherd change previous one same codes but loss mpg??? however this one great since got first code deleted n 5xdays reappear...s2 map removes dpf n this has a limiter on rpm I have been getting u1900 engine speed missing this first then surly turbo follows I am thinking overlooking obvious removed rev limiter whenever my foot allows rmp over 3.4 in 3rd and sucks over 100mg/sec pops code.
having deletd limiter is allowing me to push it n popping code.....? now I wonder I changed turbo for nothing
help please
not oil, oh had hesitation near stalled at idle and if don't neutral cae stalls at stopping however been really gentle on new turbo allowed idle pre drive and good 25secs b4 switch off.
At loss n is it worth bothering I getting better mpg newer back 56 an drives dead punchy no limp mode either
Old Jan 9, 2017 | 10:08 PM
Alan Barclay
noticed crunching though was transmittion might be abs as I gather this is integral now
Old Jan 9, 2017 | 10:11 PM
Alan Barclay
Anyone know what astock focus turbo psi setting n whats its threshold????
Any ideas pleased let me know I cant believe this one! car great to drive was sure wasn't turbo last time as was bench tested to 55 psi....but need every penny as told ref circuit on n75 and this is a recon on focus 1,6 the psa venture regretting now
