compression ratio for supercharged xr4i
Old Dec 30, 2016 | 01:13 PM
carbon1993's Avatar
carbon1993
Default compression ratio for supercharged xr4i
What is the best compression ratio for a 3.1 cologne v6.
i want to run a sprintex supercharger. But my engine has a compression ratio of 9.9:1 now.
Is this to high to run a intercooled supercharger at 7/8PSI?
Old Dec 30, 2016 | 04:02 PM
costina's Avatar
costina
Live long and prosper!!
It would depend on what type of pistons you have forged or cast.
Old Dec 30, 2016 | 04:06 PM
costina's Avatar
costina
Quick google search came up with this.
ProCharger Supercharging FAQ’s ProCharger
https://www.procharger.com/faq
Hope this helps
Old Dec 30, 2016 | 06:08 PM
carbon1993's Avatar
carbon1993
i think cast pistons. Got pistons of some volvo b23 or b230 in it.
Old Dec 30, 2016 | 06:16 PM
costina's Avatar
costina
Don't think your boost of 8psi will be too much. I guess it depends how well it it mapped/tuned and cooled.
Would have liked to have seen forged pistons but saying that some pistons are squeeze cast which again are stronger than cast.
Hopefully Stevie will see this thread and help you out.
Old Dec 30, 2016 | 06:47 PM
carbon1993's Avatar
carbon1993
Thanks! the kit normally runs on a stock 2.8 with 9.2:1 compression. I don't know which fuel system im going to use. Kjet or EFI.
Old Dec 30, 2016 | 06:49 PM
costina's Avatar
costina
I would look into running efi on a aftermarket ecu to get the best from what you got. It will also help for future upgrades lower comp more boost etc.
Old Dec 30, 2016 | 09:32 PM
carbon1993's Avatar
carbon1993
the supercharger won't do more than 7/8 PSI if it runsgood with the supercharger im a happy man. if it gets round 250Hp i wont mod it any further.
