Wanted: Tremec TKO T600
I am after a complete conversion with tko t600 (not t56) gearbox, prop, shifter, clutch, flywheel, mount etc. If you have a set up and are not going to use it or maybe going back to standard I am interested.
Missed out on 2 Saph 2wd set ups previously - cash waiting for right set up.
Let me know what you have. Get some cash to pay for Christmas.
PM me please.
PM me please.
Thanks for the link lol.
I have contacted him - I look on eBay nearly every day and only see the USA new ones. The 2 set ups I've missed have been on forums.
will let you know how I get on.......
I will be using the front yoke only as I have a single piece I use currently. Balanced properly not an issue and it's for track use only. I upgraded to thick wall 3 inch prop.
In all fairness when I really need one I will buy new and sort it. The money I was offering was near new price and there were issues with the clutch and no flywheel so deffo not plug and play.
I would have had to spend out on top and so was not prepared to go any higher.
Paul North Yorkshire Rs spares is restoring an rs500 that looks like it has a tremec in it, the cars going back to standard so maybe worth asking him if it's going to be put back in or not. What needs to be done to the flywheel when fitting a tremec?
If bell housing done properly it uses standard cosie flywheel etc with a cosie clutch albeit an uprated version.
I have a Tilton twin plate 7 1/4 I would use but would have needed the tremec centres put in.
thanks for the heads up for Paul - anyone got a contact number as it's ages since I had any dealings with him.
