Escort rs turbo electrical prob
I recently fitted new vibratechnics gearbox mounts since then Iv had some electrical issues my cooling fan come on alone with the passenger front dip beam the fan runs really slow could it be something else any help would be much appreciated thanks
Update found the problem the bolt that holdsthe 3 earth's on the driver side inner wing was all slack cleaned and tightened up all good I did think it had something to do with the gearbox mounts as the vibratechnics ones are all rubber and the standard ones have metal round them plus the problem only started when I changed them ALL SORTED NOW 👍
