Mk1 Focus RS Turbo Technics Hybrid Turbo - SOLD
As title, covered approx 6000 miles tops over the last 5 years.
Has no play in or out, slight side to side, 0.5mm either way but that's obviously with no oil in it. The oil drain has been threaded to allow a AN adaptor to be fitted, think it's M16 x 1.5 thread pitch (to avoid any leaks etc). Can still use a normal drain if you wish.
The rear housing has been rotated to allow me to fit it to the 'over the gearbox manifold' that I also have for sale. Can easily be rotated back to fit standard setup.
£200
£200
