Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
St170 power issue/ fuel issue
Old Nov 30, 2016 | 10:21 PM
Liammack170's Avatar
Liammack170
Default St170 power issue/ fuel issue
Hi all my st170 seems to be a bit poorly. Had a similar problem a couple of months ago. When the fuel level drops bellow half a tank the car begins to lose power around 4k and above. Struggles to pick up and will also cut out. Fill up the tank and it's perfect again. I installed a new Ford fuel pump and sender unit 3 months ago and has been perfect up until recently. Could this possibly me the fuel module or pump again.
Old Dec 1, 2016 | 07:10 AM
STeve's Avatar
Super Moderator
only time I have heard of this issue is when its either pump or regulator issue
