Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
Focus st 225 eml
Old Nov 27, 2016 | 03:55 PM
stu_d909's Avatar
stu_d909
Default Focus st 225 eml
Hi lads
First off sorry if this has been covered before I had a quick search but nothing came up if there's threads out there then please point me in the right direction.
I fitted my new exhaust yesterday it's a full mongoose turbo back with 200 sports cat and just got the engine management light on today. I know it's because I have placed the sensor before the cat and it's seeing it like a decat but the sensor cable wasn't long enough for me to fit it in the other sensor boss/bung after the cat so looking for options is it simply a case of buying a sensor with longer lead on it??
Thanks in advance for any help/info
Stu
Old Nov 28, 2016 | 12:15 PM
Rowe's Avatar
Rowe
Skint
you've put the rear sensor in the front hole? (if yes, that's a major big no no). Put the front sensor back where it belongs.
an angled spacer 'should' give you enough length to get the rear sensor where it should be.... however, i'd of expected the boss to be in the correct location if it's a mongoose system
Old Nov 28, 2016 | 01:01 PM
stu_d909's Avatar
stu_d909
Thanks for the reply
just incase I wasnt clear in first post the cat has 2 bosses on it. one before(turbo side) other after the cat (back box side) now the original cat had the sensor coming out the middle of it but the cable is to short when fitted in the back box side boss so to get me up and running I had to put it in the turbo side boss.
I'm no sure the angled take off would give me enough length but I'll have a look see
Thanks
Edit quick call n seemingly there's extra length to be had in the cable it's clipped further in from where I could see the other day
Old Nov 28, 2016 | 02:13 PM
Rowe's Avatar
Rowe
Skint
yeah i know dude. I used to have a 225 myself. Running number 2 sensor in the number 1 location is not a very good thing to do..... sensor 1 monitors the A/F ratio remember.
You'd of been better off leaving sensor 1 where it is and leaving number 2 dangling underneath the car. Theres a clip on the subframe and one on the gearbox, you could try moving them. There was definitely an abundance of loom when i fitted my decat with spacer. I had to tie it up with cable ties
Old Nov 28, 2016 | 03:15 PM
stu_d909's Avatar
stu_d909
Managed to get in up on the ramp this afternoon n un clipped the loom and had plenty of length just couldn't see this when I was laying under the car in the driveway over weekend so swapped the sensor positions so it's now after the cat and mechanic even cleared the code for me as well all free of charge so see how it behaves itself
Thanks again for replys mate
Stu
Old Nov 29, 2016 | 09:12 AM
Rowe's Avatar
Rowe
Skint
glad to hear it's sorted
