oil pressure?
Old Apr 9, 2005 | 05:14 PM
MARKYMARKONE's Avatar
MARKYMARKONE
Default oil pressure?
hi
can any one please tell me what the oil pressure should be at idle on a saff cos 4x4, stage 2, 69.000 miles as some times its at 26psi and others at 21 ish psi. does this sound about right
thanks
mark
Old Apr 9, 2005 | 07:40 PM
simonc's Avatar
simonc
At normal operating temp at idle it should be a minimum of 26psi.
At 2000 rpm a minimum of 35psi.
Simon.
Old Apr 9, 2005 | 08:06 PM
Alvyn's Avatar
Alvyn
all YOUR figures would depend also on what grade of oil you use
Old Apr 9, 2005 | 09:55 PM
nicksaph's Avatar
nicksaph
mines got a 25psi oil pressure switch fitted and when the oil is hot it just starts flickering at idle. oil is 10/ 50 motul
SMILER258
Sep 28, 2015 09:04 AM
