Headlamp washers
Old Nov 15, 2016 | 01:07 PM
jowdak's Avatar
jowdak
Default Headlamp washers
Hi.
I have a ST 170 with the xenon lights and washers, the passenger side washer leaks water continuously, does anyone know how to stop this.
Thanks Andy
Old Nov 15, 2016 | 02:19 PM
STeve's Avatar
Super Moderator
could be the little tank that the jet go into or failed o'ring, maybe even a actual leak on the pipe joint itself, best bet it to take bumper off and look
Old Nov 15, 2016 | 02:29 PM
jowdak's Avatar
jowdak
Thanks for that.
Is the little tank the black plastic thing the jet pushes into, presuming there is some sort of valve in it to stop the water ?
That seems to be were the water is running from and as the jet is clear it just runs through it.
Thanks Andy
