Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Broken clutch pedal pushrod
Old Nov 12, 2016 | 02:43 AM
Flavor's Avatar
Flavor
Default Broken clutch pedal pushrod
Hey guys, been a bit of a lurker here since I bought my focus but have never needed to post before.
The plastic pushrod connecting the clutch pedal to the master cylinder seems to have broken. Is it possible to just replace the rod itself? It's 2009 focus diesel.
Here's a photo: http://imgur.com/a/vwaDy
*edit*
Also, would it be a really bad idea to just superglue this bad boy back onto the clip in the pedal lol?
Old Nov 12, 2016 | 07:15 AM
Caddyshack's Avatar
Caddyshack
I would just buy the whole part from a breakers and replace it, it will only break again.
Old Dec 21, 2016 | 03:38 PM
karlos09's Avatar
karlos09
mine went on car a few year ago bought a new one fromcar spares not that bad at fitting took a bit to bleed it after but the steel rod on the pedal will be loose its that that corsed it to break needs a blob of weld to it or will break again hope this helps
