fuel pipe help...
Gents,
After a bit of advice.
Trying to locate a red fuel pipe from fuel filter (exit side) into metering unit as damaged mine and need a new one.
I'm having a bit of trouble locating one...so two questions,
1) Where can I find one!?
2) What are the alternatives if I can't locate one?
Thanks in advance.
Oskar
Thanks in advance.
Oskar
Gents,
Thanks in advance.
Oskar
Thanks in advance.
Oskar
"Think Automotive" .... http://www.thinkauto.com/
Might be worth a ring?
I had there replacement pipe.. rubber fuel pipe, 10 Bar rated.. worked fine.
Just be careful and choose strong pipe, as there is around 6 bar fuel pressure, so weak fuel pipe can look a bit like baloon when you turn off engine
get in contact with this bloke he'll sell you what you need. helped me out in the past.
http://www.ebay.co.uk/itm/Ford-Escor...cgwfcp7COhPWIA
Thanks All...
Decided to have a search around for a local specialist (bham) and hand it in to them to have pipe fitted/made up including washers/bolts etc.
Can anybody recommend anyone? I'm in Sutton...north on Bham, dont mind say a 30min trip...
